Hi Maurice I have attached a PDF for you to look over to do some checks for your locking issue. Honda_eNy1_WalkAway_Lock_Troubleshooting.pdf
1998 Civic Aerodeck 1800 VTI
Dishonesty or Not???
- The old girl!!
- Rear Wheel Alignment FRV
- FREE RADIO CODES
Hi Artur, have you still got the jade and need parts? Brian- Honda Jade Replacement windscreen
I can supply these custom made for a negotiable price if I have 1 or 2 more buyers. impossible to get in europe. not stocked OEM: 73111T4R003 - The old girl!!
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
