Steve started following Dishonesty or Not??? , Lock and walk away function on Honda Eny1 and The old girl!!
I recently bought my Eny1 ,,,which I absolutely enjoy driving I noticed that the lock and walk away function was not working ... it locks the boot but not the car and both Honda tech support and my Honda dealer agree that it should but cannot resolve the problem Does anyone else have this problem? Maurice
Lou joined the community
1998 Civic Aerodeck 1800 VTI
- Dishonesty or Not???
Hi all.I have just asked to review the service history for my Honda Jazz 2023 purchased Oct 2024.The history has that it had body repairs to the value of £950 only done a few days before purchase & a bumper swap a few days after my deposit was paid.Not a word was said about this.Has the Honda garage got the right to hide these details from me?I am now selling the car but obviously have to provide the service history for my p/ex which could maybe impact the sale???Would appreciate what owners thoughts are please.Thank you.larrygreen1 started following Dishonesty or Not???Diamondpack joined the community- Manual
- Rear Wheel Alignment FRV
Hi Chris! The major cause of the inner tyre edge wear is due to extreme camber change caused by worn out bushings in the upper arm. The adjuster bolt-nut combo which goes through the back knuckle bushing does not contribute much to the wear, it affects the car's forward rolling behavior. There are several adjustable camber kits available, which solves the tyre wear problem. Hardrace Cheaper Noname Febest Left side Febest Right sideclive joined the community61Clank joined the communityNWales joined the communityBakersone joined the community- Rear Wheel Alignment FRV
The alternator will be engine ecu controlled also i think. - Dishonesty or Not???
