Preventative Maintenance
Thanks again for your advice
1998 Civic Aerodeck 1800 VTI
gio joined the community
what is this? 2024 model
Foster33 joined the community
Who remembers these?
Steve Kernow joined the communitycolin setters joined the community- 1998 Civic Aerodeck 1800 VTI
Hi, bought my 2015 1.6 D-tec SE Plus in May and it has been great, the only thing has been the P0001 fault engine code keeps being thrown so I need to replace Fuel Preasure Regulator and Sensor to try and get this code cleared. Does anyone know where is a good place to order these from? ThanksTyredguy started following Need to replace the Fuel Preasure Regulator & SensorTyredguy joined the community- Dim low beam
