  2. Last week
  3. Earlier
  4. Hi Artur, have you still got the jade and need parts? Brian
  5. I can supply these custom made for a negotiable price if I have 1 or 2 more buyers. impossible to get in europe. not stocked OEM: 73111T4R003
  6. Hi, Desperately looking for a replacement front windscreen. The only 2 breaker jades in country don't have one intact. c.2K from japan!!! 6 month lead time. Have found someone in UK who can make a minimum of 5 of them but would need a couple of other buyers to justify. OEM: 73111T4R003 Maybe someone knows of an unlisted broken Jade somewhere? as I can have a guy who can remove the glass safely. any help appreciated. or am looking at a write off. Brian.
  7. Did either of you (or anyone else) solve this problem? Mine has started doing the same... thanks.
  8. things seemed so much easier back in the day - as long as the tyre was round then it was fine 🙂
  9. I think some of them are making a revival - at least in name though Lost too many good brewerys over the years (Ringwood Brewery my local one has now closed) :-(
  10. Alan gsd
  11. These Mk 3 Jazz's are a bit posh tyre senors, remember the good old days when every garage air line gave a different reading!!. Had a damged tyre valve yeras ago was a late at night broken at the base used superglue got me home!!!!
  12. The same as when driving, tyre pressures increase on their own in hot weather. I don't know if the tyre pressure alarm points can be altered in the car to allow for the extra pressure in the tyres ( I'm not overly familiar with the Jazz as it's my wifes), but if not then you could physically lower the tyre pressures by a couple of lbs to stop the alarm showing. Don't forget to increase the pressures when the weather cools down. There should be enough leeway in the settings to allow for some variation in pressures.
  13. My Mk 3 Jazz tyre pressure sensors have been activated frequently in the recent hot weather . A bit of a nuisance . Any suggestions please ?
  14. It should fit the apeture but Halfords stock kits to ensure the wiring and fascia are suitable
  15. I agree with you Alan, it was by far the best of all the generations so far
  16. Finally found the problem. It was my passenger’s rare ABS sensor, which had debris and was cleaned properly. All warning lights never came back.
  17. I liked my Volvo's and Transit's but my first Honda a 2005 CRV is without question IMO the best car ever. The extras and finish is just the best
  18. It's https://www.ebay.co.uk/itm/197475366333?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200818143230%26meid%3De6234bdbf97d43278ddcbf9164e6c802%26pid%3D101224%26rk%3D4%26rkt%3D5%26sd%3D205606678374%26itm%3D197475366333%26pmt%3D0%26noa%3D1%26pg%3D2332490%26algv%3DDefaultOrganicWebV9BertRefreshRankerWithCassiniEmbRecall%26brand%3DHonda&_trksid=p2332490.c101224.m- It's not mine for sale!! you could ask the guy in Doncaster the same question hahahahaha
  19. Yup. Why can't you send me yours with a courier?
  20. There one in Doncaster as well, cheaper but you have to pick it up. Thin kit was under £40. What's that about 60 odd miles from you.
  21. Thanks 😊 expensive though
  22. https://www.ebay.co.uk/itm/205606678374?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20220405142716%26meid%3Db6b4f406ffa44c468100442c1b24f502%26pid%3D101506%26rk%3D4%26rkt%3D10%26sd%3D197475366333%26itm%3D205606678374%26pmt%3D0%26noa%3D1%26pg%3D4481478%26algv%3DDefaultOrganicWebWithV11WebTrimmedV3VisualRankerWithKnnV3AndUltBRecallAndCassiniEmbRecall%26brand%3DHonda&_trksid=p4481478.c101506.m1851 Hi b4u2. if you are stil looking for a table this is on ebay £68 includng postage Alan
