colin setters joined the community
1998 Civic Aerodeck 1800 VTI
I seem to recall using a module from another manufacturer to resolve the parts supply issue at the time - could have been Rover or similar manufacturer that used the same system - at least it gives you an opportunity to widen the search. Searching by Part Numbers would be best to get straight to the correct part
New to Honda
New to Honda
Hi this is Ivan here and I have just purchased a Honda Jazz Crosstar. Not had any Honda's before and at the moment very pleased with it.
Hi all, does anyone have a working distributor or advice on where to buy one second hand or new as it has failed (garage diagnosed) on my sister whilst driving it Any help would be greatly welcome, the car is worth nothing if it isn't running :(
Ivan Myles joined the community
Oldboots091 joined the community
Water in boot MK4 CRV
SWSHondaCRV joined the community
Tyredguy started following Need to replace the Fuel Preasure Regulator & Sensor
Tyredguy joined the community
Mike Kingfisher joined the community
Dim low beam
paul turosak joined the community
Dim low beam
GeofC joined the community
Little Doggie joined the community
- Remember this?
Steve started following Remember this?
Remember this?
My best car ever, the oldest car I'd ever purchased at 15 years old now hitting her 20th years - Lock and walk away function on Honda Eny1
