Project Moff - 600BHP R33 GTS-t
Moff
Hi All, as Premium Member discount supplier, thought we would share our race car info
FULL BLOG CAN BE FOUND HERE - The Project Moff Race Car
Hi All,
I will start a blog with all the details, but I have just put this in my R33 GTS-t.. Its a bit lairy to say the least :D
Website : The Project Moff
Dyno Print out :eek:
1.5 Bar
600.8 ATH
466.8 lb/ft
Spec
Engine
RB26 Red painted engine (from an R32 GTR)
N1 oil pump
ACL Big ends and main bearings
Greddy cams and Cam Shafts
Polished crank
Ported and Poilshed head
Tomei Fuel Rail
Tomei pistons
Rips modified GTR sump, with diff removed, welded, extended and baffled
R33 GTR Engine Loom
R33 GTR Coil pack loom
Bosh 044 Fuel Pumps x 2
750cc injectors (these will require upgrading soon)
Nismo Fuel Reugulator
Greddy Camshafts
Greddy EGT Gauge
Greddy Profec B Boost controller
Greddy T78 turbo kit (with screamer pipe)
Greddy External Wastegate
Greddy FMIC (100mm)
Greddy Oil Cooler Kit
Greddy FMIC
HKS head gasket 1.6mm
HKS F Con Pro Gold Ecu
HKS Oil Cooler
HKS Hard Pipe Kit
HKS Induction Kit
Oil Filter relocation kit
Bonnet Pins (Standard bonnet catch removed)
50mm Radiator
Air Con Removed
Carbon Canistor Removed
RB25DET GearboxFront & Rear Strut brace
Exhaust
Japspeed De-Cat
Japspeed Turbo Elbow
Japspeed Downpipe
HKS R34 GTR V Spec Exhaust (custom extension added)
Drivetrain
Heavy Shockproof Gear Oil
Silkolene Diff Oil
Rear Diff From an Auto Skyline (4.363:1)
HKS Triple plate Clutch
Suspension
Driftworks Rear Camber Arms
Cusco Front Camber Arms
Polished Stainless Hicas Lock Bar
Driftworks Front Tie Rods
Tein Track Rod Ends
Tein Track Rods
Poly Subframe Bushes
Driftworks Rear Traction Arms
Ohlin Coilovers
Exterior
Full Respray
Nismo Bodykit
Custom front Splitter
Carbon Nismo 'B' Pillars
Custom Cool Louvres Bonnet Vents
Custom Sand Blasted & Orange powder Coated Subframe
Dual HID's 600k 55w. Main and Dipped Beam
Interior
Tinted Windows
2 x Recaro Seats from EVO VI
Aftermarket Racing Steering Wheel
Apexi Dual Turbo timer
Greddy Profec B2 Boost Controller
Stripped Interior
HKS Boost Guage
2 x 3" 4 Point EJS Racing Harnesses
Andy Robinson FIA Approved 7 point Roll Cage with Door Bars
Stack Oil Temp Guage
Stack Oil Pressure Guage
Stack Water Temp Guage
Brakes
Nismo Front Steel Brake lines
Brembo Front Calipers
MSU Slotted Front Discs
DS3000 Pads
Custom Moff made brake stopper
RBF600 Racing Brake Fluid
GTR Brake Cooling Ducts
Wheels & Tyres
Volks Lightweight Alloy Wheels
Toyo 888’s 255/40/17 front and rear
Abbey Motorsport 4 Wheel Laser Align
Power
At 1.5 Bar Turbo Boost pressure
Peak Power 600.8 BHP @ 7229 Revs @ Hubs
Peak Torque 466.8 lb/ft @ 6578 Revs @ Hubs
