Help
TOMMGTi
Hi there I own an 2009 crv 2.2 diesel. And for a split second when accelerating she splutters/looses power. Any advice that anyone can pass on or had similar problems like this before? Doesn't happen all the time only in 2nd gear under hard acceleration
Thanks
Tom
Edited by TOMMGTi
Hi Tom....welcome to the Forum
I'm going to go for Turbo vanes gummed up as this is quite common with high carbon content within the engine/turbo blocking the movement of the variable turbo vanes.
Would recommend a Turbo cleaning kit (available on eBay) to run through and see how that works.
Additionally, if this cures it or even partially cures it then I would recommend a complete carbon clean out of the engine (Terraclean) or similar which would clear out the EGR, etc which could also affect the acceleration.
The finally, an Italian tune up with good quality fuel always helps 🙂
Let us know how you get on with it all
Cheers . Trevor
Cheers . Trevor
Hi Trevor thanks for the reply. How big of a job is it to remove turbo to use this clean kit? Funnily enough I've not had this issue happen to me again, very odd
Cheers
Tom
