Manual transmission issues
Hi all im of need of help i just started to have isues selecting gear its real hard sometimes and then fine the next is it possible it could be fluid levels or could it be slave, master or worse any info will be gr8 many thanks rich
Hi....welcome to the Forum
It could be the colder temperatures affecting the fluid/oil viscosity which is causing the symptoms you describe.
Does it improve after a few miles when everything has warmed up?
