heated seats
Baz
just noticed both the heated seats are not working checked the fuse that is ok seems rather strange both are not working, anyone any ideas on this ? not checked the relays but would be rather odd that all four relays have given up the ghost.
That is odd, has to be a common connection, such as power feed or earth....worth starting at the switch(s) and working back from there until you find power feed
Also, is there a link between the heated rear screen or heated mirrors, do these work as they should?
  • Like 1
checked heated rear window fuse under bonnet thats  ok and tried to get the relays out from under drivers seat, and what a game that is even with seat in its highest position with the relay loom uncliped holding the plastic clips in just cannot shift the relays think i may unbolt the seat and tip it back so i can get more room to shift the wretched things, its possible they are frozen in the sockets.
