Engine Over Run
CC-VRoy
Hi all, I have a 2019 CR-V 1.5 Turbo Manual AWD. This is my third CR-V and is the best yet. The others were EX automatics and this one now has the power and driveability that the others should have had. My issue is, does any one else notice an engine overrun when changing up gears. I find this very odd and to overcome this and get a smooth gear change I find that coming off gas for a second or two and then change gear does the trick. The delay allows the revs to drop a bit and then the gear change is much smoother. Has anyone else have this or is it just me. Regards.
