Honda CRX help needed
Good Morning
I was referred to The Honda Owners Club by Honda in Swindon.
I own a 1995 Honda CRX (reg N753 EKP, engine no. D16Z6-4709549) which has failed its MOT due to high emission levels.
I have been told I need a replacement catalytic converter and was given the name of Online Automotive. They have told me they can supply what I need but asked me 2 questions , neither of which I know the answer to as I am not technically minded.
…does my car have a lamda sensor?
…does it have onboard diagnostics?
Can anyone help or offer any advice – I would be most grateful
Thank you
Dave
07867 663232
Hi Dave
Your car will probably have a catalytic converter with one lambda sensor and also it will more than likely have onboard diagnostics but in a very simple format (OBD1 or flash codes).
The emissions failure may be down to something as simple as an exhaust leak which is drawing air, a perished vaccum hose on the intake or various other issue, not necessarily relating to the catalytic converter.
An exhaust gas readout (4 gases + lambda readings) would narrow down the fault
