mic.b Posted December 21, 2012 Share Posted December 21, 2012 Really need some advice please? Quote Link to comment Share on other sites More sharing options...
PQK Posted January 28, 2013 Share Posted January 28, 2013 Yes, just me by the replies assuming you are talking 93-97 2.2 Quote Link to comment Share on other sites More sharing options...
mic.b Posted January 31, 2013 Author Share Posted January 31, 2013 No its a 98 2.3.its loosing water but non in oil or oil in water.cant find a leak,where best to look please? Quote Link to comment Share on other sites More sharing options...
PQK Posted February 1, 2013 Share Posted February 1, 2013 Check everything again, water pump , hoses, header tank etc when engine up to heat. If from head gasket in to bore when system up to pressure rather than oilway water will go from piston to exhaust without oil in water or vice versa. Check for steamy exhaust or misfire and plugs to see if any discoloured. Bad leak in to bore will damage the engine as water not compressible. Heater matrix only other area water will be circulating. Can try varouse brands of leak stopper which you put in rad but normally a short tem fix that will gum up the works. Quote Link to comment Share on other sites More sharing options...
