Adespin Posted October 21, 2020 Posted October 21, 2020 I need new tyres, what are the best for long life, at the moment i have Bridgestone Duelers fitted. Also the nearside rear tyre is wearing on the outside edge, i would appreciate some thoughts on this.
Eureka Posted October 25, 2020 Posted October 25, 2020 Personally I have had a set of Michelin CrossClimate tyres fitted to our CRV for the last 5 and a half years. They are getting to the point where I will be changing them at some point next year. They still have nearly 3mm all round. Ours was fitted with Bridgstones when we got it. They wernt that worn but I felt they were quite poor in the wet. The michelins are night and day different to the Bridgestones that were fitted. Our CRV does wear the edges of the tyres slightly but that could be down to driving style rather than issue. Have had the geometry checked and the 2006 crv we have is within factory tolerances. Maybe time for a geometry check?
Trevor Posted October 27, 2020 Posted October 27, 2020 The rear suspension is adjustable and the rear alignment is usually the reason for any tyre wear across the vehicle. Ensure that the mechanics align the rear first before moving onto any other adjustments. It also cures the cursed veering to the nearside of the road
Adespin Posted October 27, 2020 Author Posted October 27, 2020 Thanks for the info Trevor, it's something i will have to check next spring when the weather hopefully inproves. Is it like a tracking adjustment or a camber adjustment ?
Trevor Posted October 28, 2020 Posted October 28, 2020 The adjustment you need is the track (whether the wheel is pointing forward or off to the side slightly). This sometimes comes about if the rear wheel has been bumped against a kerb hard enough to knock the alignment out slightly. There are adjustable link arms but the locknuts can be a bit tight and may need freeing off first. If they start from the rear of the vehicle first and then check the front afterwards, most don't bother and just compensate by making adjustments to the front only. 1
Pompey Andy Posted November 3, 2020 Posted November 3, 2020 Falken tyres are good mid range for wear, I do 30,000 a year and last over a year.
qc2 Posted November 4, 2020 Posted November 4, 2020 Falkens are great and too often overlooked. As a brand, you could say they're the Honda of the tyre world.
Adespin Posted November 13, 2020 Author Posted November 13, 2020 On 11/3/2020 at 9:52 AM, Pompey Andy said: Falken tyres are good mid range for wear, I do 30,000 a year and last over a year. Expand What type of Falken tyres do you use?
Trevor Posted February 2, 2021 Posted February 2, 2021 Adespin Falken have been producing tyres since the early eighties and are heavily involved in motorsport and seem to have a good reputation for the road with keen prices as well. I would trust them and I'm particular with tyres !
Register a new accountSign in
