Tailgate opens every time with fob but fails to close. Tailgate light on dash constantly illuminated. If it opens I assume sensors are clean and operating also gas struts and motors work ok. No noises when fob pressed to close like beeps or whirring sound. Tried over a number of years to solve this so any further advice please
  • 3 weeks later...
Maybe worth removing the trim from the tailgate as had the same issue on a Toyota recently and found a plastic clip had dropped into the latch mechanism and was stopping it from closing
  • 1 month later...
Hi, I have 54 plate Accord 2.4 auto exec Tourer - when cold the tailgate opens off the fob, gets to fully open then beeps and closes again ---- in warm weather it works perfect, both opening and closing - even off the button on the tailgate - this tells me the motor, wiring, switches etc., are all working fine - I am going to fit new hydraulic struts shortly but need some advice as to how to get to them ( they are hidden beneath the roof lining ) I don`t want to start pulling it apart without a bit of guidance - nothing on youtube re :- the Tourer, only the saloon.
Any help or advice greatly appreciated - Thanks in advance.
Does it close ok with the button on the tailgate ?
Hi, any ideas on how to remove the roof liner at the rear - I don`t want to sart pulling it apart without some idea as to how ! I don`t want to break anything -Any advice welcome, thanks
  • 6 months later...
Hi, closes fine with button - also with the fob at anytime of year hot or cold, I think it must be some kind of temperature sensor ?
Register a new account
Sign in
