Colin Hogg Posted November 24, 2024 Posted November 24, 2024 I have a 2009 honda jazz, wondering if anyone knows what the yellow oil can with wavy line underneath means? Replaced the oil pressure sensor but light still comes on now and then especially cold start but turn the car off when it's heated up it doesn't come back on? Any other ideas to fix this other than being the oil pump?
Trevor Posted November 27, 2024 Posted November 27, 2024 Yellow light means it needs topping up generally
Colin Hogg Posted November 27, 2024 Author Posted November 27, 2024 Oil levels are spot on, that was my first guess, going to change the oil filter and see if that solves it, if not I think it's going to be the oil pump 🤦 1
Colin Hogg Posted December 9, 2024 Author Posted December 9, 2024 I've now realised from the handbook the sign on the dash is referring to the oil level sensor fault, so now need to locate where that is underneath the car and hopefully not inside the sump which would be a pain but at least I know now 👍
Trevor Posted December 10, 2024 Posted December 10, 2024 just thinking that if you are going to change it that you will lose a bit of oil so why not put a little bit more in now and see if the light stays off and what is over the level will be lost with changing the sensor I would imagine
Register a new accountSign in
