Vsa light wont go out on.my 2004 honda accord no abs light just the vsa light any suggestions
Hi....welcome to the Forum
That's strange because usually the two lights will be on at the same time if there is an issue.
If the VSA is switched off then this usually defaults to 'on' when you cycle the ignition switch.
Only thing I can think is if the ABS is not illuminating (easy to check when you cycle the ignition it should come on and go off soon after) or if the switch is broken (which is unlikely)
Let us know what you find
