Warning lights on dash
All these warning lights illuminated at the same time
Acc, vas, cmbs, vsa, tsa.
Help needed, should I drive the car ?
Edited by simon ambrosio
pic files too large
Hi Simon.....welcome to the Forum
It sounds like it is a common issue such as poor battery condition, if does not satisfy a deep discharge test then replace (Halfords can check this for you)
If you do get a replacement battery it is worth paying more for a quality one rather than a budget one.
Alternatively, it may possibly be a defective wheel speed sensor (ABS sensor) as some of the lights relate to this issue.
I would start with a battery test and go from there, otherwise it may need a visit to a local garage to dig a bit deeper
