Honda Oils !!!
Hi, i want to do engine, gearbox, diff oils, on my 2.2 diesel 2008 crv. Should i buy" honda" oils  !!!
Thanks
Phil
I would definitely recommend the Honda DFP oil for the rear differential (usually get 2x 1 litre bottles to flush and refill the fluid.
Engine oil, ensure it is Honda spec (ACEA) and you can't go wrong
Thanks
Phil
Hi
On my 2.2 I-dtec Accord i used Mobil 1  0-30 ESP Oil in the Engine and Honda Transmission Fluid in the Gearbox. I now have a 2017 MK4 CR-V and will be using Castrol Edge Pro (which was apparently developed jointly with Honda for their Diesels)   in the Engine and Honda Transmission Fluids everywhere else all from Coxes Honda Parts. I think it's all a case of personal choice as long as lts the correct grade and spec and it's a quality oil its down to Brand loyalty
Edited by Gazza
missing words
