  • 3 weeks later...
On 10/27/2020 at 10:19 AM, Trevor said:
Feel free to jump in and answer any posts you want....much appreciated 🙂
Will do. You won't be able to shut me up....
  • Like 1
  • 4 years later...
@OLSTERMEISTER
civic dtec 1.6.
new battery
new alternator
new battery sensor
auto stop start still not working.
car has been told it has a new battery.
also almost around same time
folding mirrors, electric windows and alarm wont work
fob has new battery
tried all the reset procedures for all the above issues.
im almost a grand in on both problems and no one can fix it.
any ideas?
Do your interior lights come on when you open the doors? Have all the fuses been checked?
It really needs to go onto a live data session to see what inputs the BCM is seeing. From what you've said it sounds like a problem with the BCM. You havent mentioned if that a reset had been done when the battery was changed. Also the battery management system might need a reset also. Could be why the stop/start isn't working. anybody with half a brain would be close to finding the problem on live data.
Posted (edited)
Hi.
yes everything else works fine and fuses checked by myself and garage, its just those mentioned but it all started when the alternator went kaput and lit the dash up like a xmas tree. Yes, the car was told it had a new battery.
i have disconnected the black wire on the battery many times, removed the negative cable from the battery many times. Tried the leave ignition on without running for 10 mins, cycle ignition thing 5-6 times without starting. The garage i took it too showed me the computer readout and it was green for everything. No faults showed up at all
Edited by Robdelnappio
Register a new account
Sign in
