Engine power improvements
I’m looking to upgrade my engine’s power supply either by remapping or other means.
I have a Honda BRV petrol 88kw and the engine is very lazy at low revs: 2-3500 rpm
as the revs increase beyond this the performance is adequate.
You did not state what year Your CR-V is,?
My apologies it’s a 2018 Honda BRV 1,5 ltr petrol 88Kw L15 engine.
The BR-V is not sold in the UK so not too sure of what performance mods are available for this model.
However, a Tuning Box which interfaces with the injectors is something to consider as it may be available for the engine range used in other Honda models and works extremely well at adding a lower-end torque increase.
Somethings wrong, the turbo charged models usually have good spunk in that power range. How many miles do You have On her ? could need a tune up, valve lash adjustment.... G
