CRV high pressure power steering hose
Hi all,
Just after a bit of advice, have the 2.2 diesel 58 plate.
There is a leak on the power steering hose. Was told that the honda accord 2.2 pipe would fit.. it doesn't. (Tried this because the accord pipe was £20 compared to the crv pipe which is £96). The only difference was the thread was different and the male connector was wider.
Anyone had the same problem and know a way to find a cheaper one? Every single scrappy I've contacted has sold out of them as soon as they get them in and talking mega bucks going to main dealer which we can't afford.
MOT due soon and it will definitely fail on the amount its leaking.
Thanks in advance
Kelly
Hi Kelly....welcome to the Forums
You should be able to source a company in your local area that can repair or make a new one at very little cost.
These companies usually make hydraulic pipes and hoses for diggers and trucks but can replicate your one if you take it in with you.
