Hi all, have a FR-V 2006 CDTI, and need to work out the location of the power window relay.
Can anyone help (no power windows, so I'm guessing it's a common point of failure)?
Thanks, Ian
Not the cheapest/easiest way but if all else fails you can subscribe to Honda MaRIS for an hour for €10, which should have the diagrams and instructions you need.
If it's a fuse that you are after (rather than a relay), at least for the fuse box in the engine compartment there is a diagram of which fuse does what on the underside of the plastic fusebox cover. It may be worthwhile looking around to see if there is a similar diagram on something you have to remove to access the other fuse box (if that's indeed where the relevant fuse is).
Thanks, I didn't know MaRIS, it looks like a possibility.
As you've said, the fuses are easy enough to identify, ay least the one's that aren't tucked under the steering wheel, why there?
Thanks for your reply.
Cheers, Ian
