Can anyone help? Honda recently changed the battery in my 67 plate HRV, after they changed it they said all the lights were on and it has a VSA unit fault, which will cost £2000 to replace. There was not a fault before replacing the battery and everything was working fine. Has anyone had a similar issue?
Sounds like either they haven't reprogrammed the VSA to register the new battery voltage or it needs the battery negative lead disconnecting for about 30 minutes and reconnecting to learn the new settings
Hi Trevor, thank you. If I tried takeg the lead off would it mess anything up?
