I have a honda civic 2014 and recently warning lights have started coming on while driving
First the car wouldn't start so I changed the battery which rectified the problem however after driving around 10 miles the warning lights reappeared
Alternator is good this is charging the battery, all fuses good also, so not sure what this could be
Any ideas would be much appreciated
Does the battery need coding into the vehicle - e.g. vehicle may have to recognise new battery voltage otherwise will still be reading the old voltage
If in doubt, worth checking to see if it has this function
