ENY1 Moisture Inside
Hi. I have the advance model with 2k on the clock. I am getting moisture on the glass roof and windows on the inside. Sometimes it forms water droplets but they have not dropped onto the seats yet. I have taken it back to the dealer and they said there is nothing wrong. Fogging also happens when driving. My concern is that this moisture will be going into the fabric etc and could eventually cause a musty smell or mould. Has anybody else had any issues. Thoughts would be greatly appreciated.
Edited by Nath77
Photos uploaded
I assume you don't have the recirculate vent closed, sounds as if you aren't introducing fresh air. Try auto setting on heater that will bring in dry air as it will utilise the A.C
Thank you for reply. I really appreciate your support. Today the saga got worse… ice is now forming on the inside of the vehicle. I’ve contacted Honda and am hoping to hear back soon but I would not expect this on a 2024 car with 2k on the clock.
This is bad, it is bound to be forming on other out of view components too. Only ever seen this many years ago on Alfa Romeo Giulietta when it turned out to be windscreen seal not fitted correctly. Is the drain from AC blocked and entering car? You could leave AC off and just try it with fresh air entering, Mention that to Honda Tech, but that will take time for an answer. Sorry, can't help further.
