New jazz hybrid hybrid battery hot
I have just purchased a new jazz hybrid,  can someone tell me why on some journeys when I turn the car off an image appears on the dashboard showing the hybrid battery in red, I assume it means it's hot, but we are in winter should it be hot? Do I need to do anything?
  • 4 weeks later...
I posted this in January and maybe I didn't explain it correctly I now have a photo of what i see when I turn the car off, it's not every journey but have no idea what it means, it is not in the handbook. 20250223_133148.thumb.jpg.3f41d11050ad20aadfaa0ffa9742330a.jpg
It means check rear seats can be turned on/off in settings
its to let you know if you have left anything or got anything
on rear seats.
You haven't got your warning message switched on otherwise it would tell you
 check in customisable features of the driver information display if the setting for the <warning message> is still in its default off setting then turn it to ON this will give you a helpful and clear message with the icon, it will give other information as well no one can understand why honda has default setting at off.
https://clubjazz.org/forum/index.php?topic=17417.0
