Why current fuel consumption jump up and down in idle?
Why does the Honda CR-V Diesel’s instantaneous fuel consumption sometimes fluctuate significantly between 0 and 20 liters per hour while idling, even when the engine's RPM is steady?
Hi everyone, I’ve noticed an issue with my Honda CR-V Diesel 1.6 i-DTEC while idling. The instantaneous fuel consumption fluctuates significantly, pulsing between 0 and 20 liters, even though the engine RPM remains stable. This behavior has me puzzled, and I’m wondering what might be causing it.
I’ve considered factors like the ECON mode, auxiliary systems, DPF regeneration, and potential sensor glitches, but I’m not sure if these are the main reasons. Does anyone else with the same model experience this issue? Are there known solutions or insights into what might be going on?
Any advice or shared experiences would be much appreciated—thanks in advance!
  • Could the ECON mode or other settings be influencing this behavior?
Edited by Angelov
