Rich
  1. I have just seen this reply, there is no mention of dual mass flywheel been replaced. I think there plays my problem
  2. Hi, 7 months later my car still does this, I've just put up with it, been to garage they said to change the whole clutch and dmf, i have a rattle on the passenger side when clutch is pressed in it goes away. Was told it's the throw out bearing. Apparently there is a little fork mechanism rattling. Really annoying put gonna ignore it until it falls apart
  3. I've got the same issue, I was thinking it maybe a driveshaft, the clutch on my car was replaced 15000 miles ago. Looks like I will be taking it into a garage. If I can sort this I'd be happy.
  4. Did you ever get to the bottom of this, mine is doing the same 2009 diesel.
  5. Rich joined the community
  6. Hi I purchased a 2009 crv 2.2 cdti. 118000 miles on the clock with service history. Clutch was replaced 2 years ago. I have a problem when i change gear from 1st to 2nd and 3rd to 2nd, the car shudders, then goes, every other gear is fine and clutch doesnt seem to slip. The rear diff has been flushed out and refilled as it needed it. Any ideas greatly appreciated. Thanks Richie
