Steve sheargold
  1. Put the archoil in thrashed the gal abit, at night I emvasise, all seems well trev, the Italian tunup seems to have worked, got some serious turbo lagg though I've noticed, struggle to get to 4th unless I thrash through the gears??!
  2. Looked in the service manual told me to use 0w-30 so have done , was doing it before oil change, does this engine have a pcv valve? I've got some archoil 6400 Dmax fuel additive to put in it yet the reviews are outstanding ment to clean all carbon buildup from the engine.
  3. 118k sounds fine from what I can hear, changed all filters, air,oil,fuel and oil change bout 2 weeks bk read that it can be pcv not sure if there is one or where its located, checked the egr's with pressure trigger, the both seem OK no vacuum leaks???
  4. Hi all started to get abit of blue smoke and read would be pcv valve does the deisiel 2.2 I cdti have a pcv or just a breather and where is it located a pic would be great if poss. Many thanks
  5. Steve sheargold joined the community
  6. Hi all started to get abit of blue smoke and read would be pcv valve does the deisiel 2.2 I cdti have a pcv or just a breather and where is it located a pic would be great if poss. Many thanks .
