alc59
  1. Now fixed. Honda FRV front washer pump is £60+. Aftermarket Jazz 02-08 pump is £10 and fits. The difference is that the FRV has two pumps with connectors that ensure that you don't get the connections mixed up for the front and rear washer pumps. The aftermarket pump will accept either connector. Thanks for your advice Al
  2. Hot water treatment hasn't worked. So it's off with the wheel and pull back the wheel arch liner later this week.
  3. Thanks for the above. The hot water treatment has to be worth a try before embarking on taking stuff out to get at the pump.
  4. I'd got the idea there are two pumps, one for the front and one for the rear. Does anyone know if the same pumps are used in other honda models?
  5. alc59 joined the community
  6. My windscreen washer has stopped working. The rear window washer still works. Is there a fuse I should check? How do l get at the pump?
