dsmusicmaster
  1. that is also solution, thanks. I just wanted to know if somebody knows or experienced that and can tell if coolant that appears on that spot on photos if it can be from water pump or intake manifold, head gasket or...???
  2. After the car is off overnight for lets say 8 hours I found antifreeze leak on a small flat metal part behind engine. Can somebody tell where it comes from? pictures attached After driving I have to wait those hours for that leak to appear there. no overheating though.
  3. thank you for answer, as for how long ago it took place, radiator changed and system flushed about 2 weeks ago.
  4. Hello, I have bought Honda CRV 1998 automatic. And have coolant problem. Mechanic put new radiator, new cap, pressure tested = changed hoses that were leaking. Pressure test again no visible leaks at all, holding pressure fine. Now I still lose 100 - 150 ml of coolant after 40 kilometers that I drive per day. When engine is cold next day morning I open radiator I see no coolant even after I squeeze that thick hose, but fits there only 100 or 150 ml of water /destiled of course/. If engine is hoter - 2 hours after driving and I open it I still can see little water after I squeeze that thick hose. Till morning it will be again no visible coolant even after squeezing that thick hose . /100 ml will be gone/. Level of coolant in reservoir tank is still the same, dont moves. hoses are clear no blockage. I dont have coolant in oil or oil in coolant,. when open cap on engine no signs for head gasket problem. No leak in cabin after heater is on, works fine. No water in exhaust, no white smoke. No noises like water pump problems. There is still some rust in the system coming slowly after flushing because previous owner or his mechanic probably did not take good care of it /I see a little rust on radiator cap/. My mechanic said is still air in the system. Well they flushed it twice, no change. Temperature while driving is stable all the time /in the middle, slightly behind/. Couple of times happened that after 4 hours engine off I turned it on and temperature jumped immediately to the middle /its operational temperature/, after 200 meters dropped very little /2 milimeters/ and came back immediately and stayed there for rest of my short trip. Also in the morning after I turn the engine on car is still in Park position, and the temerature gets to its operational temeprature in the middle after about 3 or 4 minutes, slowly continuosly, but I think it is too fast.
