Bon Scott
  1. Nothing is in the wrong place and everything is connected properly. I just need to find the main relay and test it as its the onlt thing i haven't tested, i just cant find it
  2. Compression is fine. Im a mechanic and have done every test there is. The PGMFI relay controls the fuel pump and the injectors. Iv uplugged the fuel line to the injector rail and as soon as i turn the key it pumps fuel out of the hose so the pump is fine but something is stopping the injectors. They're not clogged iv swapped them with ones off of our other FRV which i even started up first so i knew they worked. The green flashing key signal doesn't stay on so its not a key coding issue. Im sick to death of it now. It ran fine before but was over heating due to the gasket. Then ran beautiful after id replacef the gasket and belts until it suddenly cut out while driving. The cam belt hasn't moved either and i have run out of ideas. Plus its stuck outside my house so i cant even get it to work. I want to set fire to ******* thing
  3. Bon Scott joined the community
  4. Hello does anybody know where the PGM FI relay is ? Iv got a 2005 1.7 FR V that iv just replaced the head gasket and all the belts on. It worked fine for 20 miles or so, making various stops for shopping and then on the motorway it just cut out and wont start at all. Theres spark from the plugs and fuel is pumping to the injector rail but they're not firing. apparently the PGM FI relay is a common fault on Hondas and when they fail either the fuel pump stops working or the injectors. The pump is pumping. So i just need to find it and test it or swap it with the one in my other FRV which the clutch has gone on. Iv looked on both fuse boards plus looked behind the glove box and checked there. Whilst there i reset the fuel cut off switch but still no ignition. Any ideas ?
