Pao1os
  1. Trevor thanks for the welcome and advice. I was puzzled by the recommendation to change the clutch too. As the car currently has just under 60k on the clock it may be that they just think its due. The I-MID display selector changes between the screens fine and displays the radio and clock fine, its just the digits from the trip computer which don't show. When you say the select button do you mean the one on the steering wheel with the different page icon? Thanks
  2. Hi everyone, New to the forum but wanted to get some ideas: I have a 2012 CRV 2.2 Diesel manual with 60k miles. On a recent service (at a Honda dealer) they advised that it needs a new clutch. This seems a bit odd to me as the reason given was that the clutch bite was high. It does not have any symptom of the clutch failing such as power loss or difficulty engaging gears. The only thing which could indicate a problem is a very slight, intermittent judder changing between 1st and 2nd gear but this was not mentioned. The other issue is that the middle display (centre top of the dashboard) for range and MPG is blank. The display itself works as the clock and ICE information still appear when selected, as do the range and MPG titles but the actual trip computer info is missing. The trip computer info still shows correctly in the display in the middle of the speedometer. Any ideas most welcome.
