Floyd
  1. I've been looking on ebay for one as well, I only have one so a spare would be good. They seem quite hard to get though. I have seen a couple of sites online with instructions on how to program a s/h one yourself, without a main dealer visit... https://www.transpondery.com/remote_programming_instructions/honda/crv.html ...for when/if you find one.
  2. EML
    Floyd posted a topic in CR-V 2001 to 2006
    Just noticed the eml does not come on with ignition...any ideas why not please?
  3. Sorted...didn't realise you had to push key in to turn to lock position. next problem, why can I remove key when in accessory position ??
  4. Just bought myself a 2003 CR-v with sat nav & cd system... Usually there is an accessory position on the ignition swith, not on mine though! One turn of the key brings all dash lights on then next turn starts car, also the radio has to be turned off manually, ie there is no position on the ignition switch for accessories, radio, windows etc... Is this normal? Thanks guys
  5. If you,ve replaced the cat with a cheap aftermarket one, this will often throw a code relating to the O2 sensors. Unfortunately only real way to deal with it is a proper oem cat...expensive I know
  6. Have you read all the codes and deleted them?
  7. This sounds like the water is draining back into the reservoir, is there a non-return valve fitted?
