honda1
  1. I have just brought NGK - Spark Plug - IZFR6K-11S what torque setting do i use on these?
  2. Hi looking at changing spark plugs on a 2009 civic 1.8 petrol, i have a torque wrench so could do myself which ones would i need and is there a torque setting for them or can i just do hand tight with a wrench? Thanks
  3. Bit of an update just got back from mr clutch there was air in the system from when the other garage changed the master and slave cylinders, they also said clutch was not worn like we got told wont be using them again happy with mr clutch drives good now shakes abit at idle think it could be spark plugs will have to look into those
  4. Just abit of an update garage said the clutch master cylinder was leaking so had that changed which was better for a week then started crunching gears again after a week or 2 so garage had it back said the slave cylinder was now leaking so changed that much better at the moment but 2nd gear seems to crunch every so often they also said the clutch was showing signs of wear and tear could this be our 2nd gears issues? It mainly does it coming down the gears into 2nd Thanks for any help
  5. Thanks Trevor i will give these a try
  6. Hi Good evening, would like some advice please... so few weeks ago changing gear was getting harder and harder and was grinding gears so took it into a garage who replaced the clutch master cylinder said it was leaking and had no fluid in biting point is really low to the ground but no clutch slippage. 2 weeks on biting point is still pretty low to the floor and sometimes still grinds putting it into a gear its much better than it was but still occasional, also the gear lever in general feels like it could go in and out of gears a bit easier not the smoothest ... anyone any ideas?? does it need a clutch adjustment or gearbox oil change? kind regards
  7. Hi im looking for a very nice honda frv petrol maunal or auto, for my 2013 toyota verso, it can seat up to 7, has a 2.0 D4D engine with approx 119,000 miles in daily use, full service history mainly toyota dealer and is 6 speed manual Car is in grey metallic
  8. Doesnt seem to be many automatics about so i would consider a manual.
  9. Doesnt seem to be many automatics about so would consider a manual.
  10. Trevor thanks for your reply i can confirm its on the outside, we got a pack off believe it or not armour headlight wipes from halfords for £9 and was stunned when they actually worked! 5 minutes of cleaning and they look much better Thanks for your comment
  11. Hi my mums type s civic front headlights have been advised on the mot as being faded can these be cleaned easily looks like its inside the light ? I saw on youtube you have to take the front bumper off to pull the lights out is that correct? Looks like a lot off work Just had another look not sure if it inside or outside thats faded.... Thanks for your help
  12. Hi im looking for a very nice honda frv automatic for my 2013 toyota verso, it can seat up to 7, has a 2.0 D4D engine with approx 119,000 miles in daily use, full service history mainly toyota dealer and is 6 speed manual Car is in grey metallic
  13. Hi im looking for a very nice honda frv automatic for my 2013 toyota verso, it can seat up to 7, has a 2.0 D4D engine with approx 119,000 miles in daily use, full service history mainly toyota dealer and is 6 speed manual Car is in grey metallic
  14. Hi everyone, i currently drive a diesel Toyota Verso 7 seater and im wanting to come back to honda for abit more thrills, used to have a 2.4 accord automatic which i loved driving before having to accommodate more children so im looking at coming back and selling my toyota or part exchanging it for a automatic petrol FRV and doing some bits with it, so i will be looking around the forum for help on getting one! Thanks in advance looking forward to join honda again!
