I would personally remove the tray as it will actually increase the corrosion. The tray is fitted by the manufacturer for several reasons....reduce oil leaks reaching the road surface or driveway, noise reduction, aerodynamics and increased fuel economy and many other reasons but none that would be vital if you removed it completely. If there is dirt, corrosion or loose components beneath the cover you would never know. Seems strange if it has been serviced that it is still on there - I always remove them from my cars so I can see an oil leak starting or any loose or damaged components on the underside. At the same time you would more than likely be able to access the washer pump from there as well. I recently fitted an aftermarket washer pump to a Mazda and it works fine (for less than £15).
PRE PURCHASE INSPECTION
Well, you might just as well give your son your wallet and see how he gets on with finding something nice (but sensible enough for insurance) 😁 Not sure what the answer is, but having bought an excessive amount of cars over my lifetime I always come back to that gut feeling. In other words I buy with my heart rather than my head and although that sounds foolish, it has always worked for me (mostly). If it feels bad and you are getting those vibes then walk away....there are usually some many clues about the provenance, owner(s), previous repairs, etc - as they say 'if it walks like a duck..." Good luck with your search and let us know how you get on with finding a decent car for him. Got to go now, as just about to start my working day and night with numerous jobs to fund my addiction for old cars and motorbikes 🤣
Towbar fitting - messy bumper
It was brilliant !!
FR-V 2008 2.2 pcv valve
- Keeping Civics alive.
- Christmas
- DRL Jazz 2014 v-tec.
Hi all, admins delete if inappropriate, either way thankyou for your help and advice. Up for grabs here: 1998 Honda Civic Aerodeck 1.8 Vti for sale | eBay - Keeping Civics alive.
