Weird beeping
I have an unusual issue. I left the car parked for four weeks. Started fine, however I have four rapid beeps, this goes of when i get above about 10mph, it also goes off when stationary when I apply the handbrake. Cannot find anything about what this annoying beeping is. Apart from this the car drives well, and the Japanese voice and sat nav in Japan is a great talking point
Brucecam1 joined the community
i have had my 2001 honda civic 1.7 coupe since 2016 previous owner from new was a family member. the car has done 63500 miles with history. fully maintained. this car is now a rare site on our roads. as i am now getting on in years i am looking for a dedicated honda lover to take it of my hands and take care of it.
guy fotheringham joined the community
JayEnBee started following Spacesaver Wheel Available FOC
JayEnBee joined the community
mnn135 joined the community
Heater motor fan inop.
HAPPY NEW YEAR...
BobbyMitchell2016 joined the community
HAPPY NEW YEAR...
HAPPY NEW YEAR...
Steve started following HAPPY NEW YEAR...
HAPPY NEW YEAR...
- Heater motor fan inop.
Hi, my heater blower stopped working, but new ones are expensive, did the 05/06 civic blower heater work for you and the connectors are same ? i have an FRV 2.2 CDi RHDfirestik joined the community- my E NY1 only charges to 100 mils and battery full
Hi fellow members any ideas!?Chippyminton joined the communityLaurence started following New Members IntroductionsLouis Levy joined the communityChristopher Anderson joined the community- Zappi app tells me the battery is full when it’s n
Zappa charger tells me the battery is full when it’s notLaurence started following Zappi app tells me the battery is full when it’s nLaurence joined the community- Christmas
- DRL Jazz 2014 v-tec.
My 2014 Jazz is not fitted with Daylight running loghts, thinking of retro fit. Notice that cabin fuse box has pos15 labelled DRL, does this mean the car is wired for DRL ready for lights to be fitted. Any motor sparky help Thanks BB- 1998 Civic Aerodeck 1800 VTI
