Fleecedbymysonagain joined the community
Towbar fitting - messy bumper
brick2112 started following Undertrays and wash pump advice
Ruth started following Need advice on where to get a replacement Air Con Unit etc.
Hi There I need to get a replacement Air Con Unit fitted on our 2005 FR-V 2.0 Sport Petrol car. We are in South East London. Any suggestions on where might do this well for us and where to get the parts from if necessary? Thank you! Ruth
Ruth joined the community
Pimpampaume joined the community
It was brilliant !!
FR-V 2008 2.2 pcv valve
John W joined the community
I'll have a look. All the mats are dry which strange. Thanks for your response Trevor.
It was brilliant !!
Had to post this. One of the jobs I did was to drive a FX4 Fairway, It was GREAT !!
Check out this address, it may help, Exoracing Ltd https://exoracing.co.uk › blog › how-to-install-honda-detent-springs
More info required here...
Crv jumping out of 2nd gear
Shaun62 joined the community
Neil Coumbe joined the communityPaul McDowell joined the communityjim maclachlan started following Trevor- FR-V 2008 2.2 pcv valve
hi all I own honda fr-v 2008 2.2 n22a2 engine but im unable to find the pcv valve. Can anyone please spot its location ? Thanks- Keeping Civics alive.
not sure, sorry! but I would try to find the most reputable rebuilder rather than the cheapest as they are incredibly complex and expensive to put right afterwards. Surprised there are no exchange / rebuilt boxes out there- Automatic gearbox repair
Looking for an automatic gearbox or sumone who can repair it near glasgow- FRV Heater Fan Blower replacement
Replacing the heater fan. Honda FR-V- Honda N600 ('J' registration)
Hello, My Dad died in August 2025. He had kept an old N600 in his garage for 40 years - always planning it to be his 'next project'! It is not in good condition, but I would say it's surprisingly good for 40 years! It hasn't run since approx 1985 - so it would require a complete rebuild. I'm not hoping for much - would just like it to be of some use to someone! At the very least, is there a market for spares etc? (ps: the photo is a bit sad - I have since cleared away all of the surrounding rubbish! As you can see, the engine and chassis are still 'in one piece'!)Huw Jenkins started following Honda N600 ('J' registration)- FRV Heater Fan Blower replacement
Hi i am trying to remove the screws which holds the fan blow, first 2 screws are easy to access, however, the third screw is difficult to get to, has any replace fan blower on FRV or has any tips on how to reach the third screw? Thanks- Water in the spare wheel well.
eBay link to a Smoke Generator: Smoke Generator- Water in the spare wheel well.
Also, it could be leaking through the tailgate seals or even rear screen washer hose is damaged and allowing water to drip into the boot area. The ultimate way to resolve the issue is to run a Smoke Generator inside the boot area and see where it comes out from- Water in the spare wheel well.
More than likely coming through from the rear light clusters - worth removing them and seeing if the gaskets have been letting water past them. If so, and before refitting it would be prudent to smear some silicone on the gaskets before refitting them- Dim low beam
Thats good to know as a recommendation for others, thanks!
