Who remembers these?
Steve Kernow joined the communitycolin setters joined the community- 1998 Civic Aerodeck 1800 VTI
I have found water drips from the air pressure vent ending up on the floor also. Have new one ready to replace and seal in! This is a 2017 CRV. Should add that I have been a CRV driver since 2005 and this is the first one to show a waterleak.SWSHondaCRV joined the community- Earlier
- Need to replace the Fuel Preasure Regulator & Sensor
Hi, bought my 2015 1.6 D-tec SE Plus in May and it has been great, the only thing has been the P0001 fault engine code keeps being thrown so I need to replace Fuel Preasure Regulator and Sensor to try and get this code cleared. Does anyone know where is a good place to order these from? ThanksTyredguy started following Need to replace the Fuel Preasure Regulator & SensorTyredguy joined the communityMike Kingfisher joined the community- Dim low beam
Maybe worth increasing the pressures by a couple of psi to see if this extinguishes the warning. You can always let out some air but also good to check you don't have a slight leak on one of the tyres. Resetting the pressure settings on the vehicle may just be masking a fault in one of the tyres Also, ensure you check the tyres when coldpaul turosak joined the community- Tyre pressure monitor on 2013 Honda civic es i-vtec 1.8.
I have a 2018 crv, currently has 62000 miles. I've never been pleased with the low beam brightness. Its fitted with H11 55 watt halogen bulbs which look OK. Looking online I can upgrade to H11 exeon or H11 LED's, but both seem to be 60 watts, and a huge amountof lumins more. I don't want to dazzle on coming traffic but I do want to have brighter lights without having the need for adaptors. Has anyone changed/upgraded their lights. Alternatively is new halogens the solution? I've fitted blue bulbs in the past which I didn't think made much difference. Full beam is fine.GeofC joined the communityLittle Doggie joined the community- Remember this?
I had this with my wifes Yaris. I asked for the service history and it only had the one thing on it, but it did have a stamped book in the car. 6 months later i asked another branch of the same group, and it had an air-con fault reported but not resolved, air con still works but slightly noisey for past year. I was well annoyed and he moved on so i could not bollock him for it. Now have even lower trust in dealers now. To be honest £950 is not a lot and would not have any affect on the car, the car has not been written off (maybe you should check with carvertical) I recently had a bumper replacement because a fox ran in to it at full pelt. needed a whole new bumper. did not affect the rest of the car at all. If it was a category right off then they would of had to tell you. Best thing is to say it had a replacement bumper, be honest up front. People tend to not worry so much if your are straight upfront. Oh yes they were slightly dishonest for hiding it.
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
