JayEnBee started following Spacesaver Wheel Available FOC
JayEnBee joined the community
mnn135 joined the community
Heater motor fan inop.
HAPPY NEW YEAR...
BobbyMitchell2016 joined the community
HAPPY NEW YEAR...
HAPPY NEW YEAR...
Steve started following HAPPY NEW YEAR...
HAPPY NEW YEAR...
- Heater motor fan inop.
Hi, my heater blower stopped working, but new ones are expensive, did the 05/06 civic blower heater work for you and the connectors are same ? i have an FRV 2.2 CDi RHDfirestik joined the community- my E NY1 only charges to 100 mils and battery full
Hi fellow members any ideas!?- Earlier
Chippyminton joined the communityLaurence started following New Members IntroductionsLouis Levy joined the communityChristopher Anderson joined the community- Zappi app tells me the battery is full when it’s n
Zappa charger tells me the battery is full when it’s notLaurence started following Zappi app tells me the battery is full when it’s nLaurence joined the communityStuartwb joined the communityNorthernswimmer joined the community- Christmas
- DRL Jazz 2014 v-tec.
My 2014 Jazz is not fitted with Daylight running loghts, thinking of retro fit. Notice that cabin fuse box has pos15 labelled DRL, does this mean the car is wired for DRL ready for lights to be fitted. Any motor sparky help Thanks BB- 1998 Civic Aerodeck 1800 VTI
