PRE PURCHASE INSPECTION
Minor update, not Birmingham, actually in Cardiff, details details…..
Hi My son is fast approaching 21, thankfully the last of my offspring to reach the milestone. Made a poor choice with my other kids that trail-blazed before him in that they received a car as their 21st birthday present. Joint family effort to combine funds enough to get them something safe and reliable. This now sets a precedent that I cannot avoid, additionally he has also picked up my petrol head affliction and more specifically, he loves all old Hondas. I suspect this is also my own fault as he has been my best companion when out driving my S2000. Many years of he and I giggling as it pings off the limiter to blame for that. I would get him an old S2000 but I fear it would be a very poor choice, at 21 years old such a thing would have rapidly been the end of me and I think it would be the swift demise of him… Well aware of his approaching gift, which he sees as his birthright, he has been hard at work searching for his dream. He has found a Civic EM1 VTi that looks to be solid, have spoken to the owner and asked the normal questions and have not been sufficiently put off yet. The issue is that the car is located a long way away so before I traipse across the country I would like to have it inspected so I don’t waste my time and money. Despite my best advice he found the car through face book market place (in no way sketchy!) which does not inspire confidence in any way at all, even more reason to have it looked at. I don’t think AA/RAC etc would be any good for a car like this, it really needs specialist knowledge of old Hondas and B16. So I am hoping someone knows a decent Honda specialist in the area or could recommend a garage with knowledge of old Hondas that might be able to go take a look at it for me. The car is in Birmingham. Any help very much appreciated, not with the petrol head thing, way beyond help with that :) Cheers
Fleecedbymysonagain joined the community
Towbar fitting - messy bumper
brick2112 started following Undertrays and wash pump advice
Ruth started following Need advice on where to get a replacement Air Con Unit etc.
Hi There I need to get a replacement Air Con Unit fitted on our 2005 FR-V 2.0 Sport Petrol car. We are in South East London. Any suggestions on where might do this well for us and where to get the parts from if necessary? Thank you! Ruth
Ruth joined the community
Pimpampaume joined the community
It was brilliant !!
FR-V 2008 2.2 pcv valve
John W joined the community
I'll have a look. All the mats are dry which strange. Thanks for your response Trevor.
It was brilliant !!
Had to post this. One of the jobs I did was to drive a FX4 Fairway, It was GREAT !!
Check out this address, it may help, Exoracing Ltd https://exoracing.co.uk › blog › how-to-install-honda-detent-springs
More info required here...
Crv jumping out of 2nd gear
Shaun62 joined the community
Neil Coumbe joined the communityPaul McDowell joined the communityjim maclachlan started following Trevor
- FR-V 2008 2.2 pcv valve
hi all I own honda fr-v 2008 2.2 n22a2 engine but im unable to find the pcv valve. Can anyone please spot its location ? Thanks- Keeping Civics alive.
not sure, sorry! but I would try to find the most reputable rebuilder rather than the cheapest as they are incredibly complex and expensive to put right afterwards. Surprised there are no exchange / rebuilt boxes out there- Automatic gearbox repair
Looking for an automatic gearbox or sumone who can repair it near glasgow- FRV Heater Fan Blower replacement
Replacing the heater fan. Honda FR-V- Honda N600 ('J' registration)
Hello, My Dad died in August 2025. He had kept an old N600 in his garage for 40 years - always planning it to be his 'next project'! It is not in good condition, but I would say it's surprisingly good for 40 years! It hasn't run since approx 1985 - so it would require a complete rebuild. I'm not hoping for much - would just like it to be of some use to someone! At the very least, is there a market for spares etc? (ps: the photo is a bit sad - I have since cleared away all of the surrounding rubbish! As you can see, the engine and chassis are still 'in one piece'!)Huw Jenkins started following Honda N600 ('J' registration)- FRV Heater Fan Blower replacement
Hi i am trying to remove the screws which holds the fan blow, first 2 screws are easy to access, however, the third screw is difficult to get to, has any replace fan blower on FRV or has any tips on how to reach the third screw? Thanks- Water in the spare wheel well.
eBay link to a Smoke Generator: Smoke Generator- Water in the spare wheel well.
Also, it could be leaking through the tailgate seals or even rear screen washer hose is damaged and allowing water to drip into the boot area. The ultimate way to resolve the issue is to run a Smoke Generator inside the boot area and see where it comes out from
