Water in boot MK4 CRV
SWSHondaCRV joined the community
Tyredguy started following Need to replace the Fuel Preasure Regulator & Sensor
Tyredguy joined the community
Mike Kingfisher joined the community
Dim low beam
paul turosak joined the community
Dim low beam
GeofC joined the community
Little Doggie joined the community
- Remember this?
Steve started following Remember this?
Oskar joined the community
PeterC joined the community
Remember this?
old timer joined the community
Hi all.I have just asked to review the service history for my Honda Jazz 2023 purchased Oct 2024.The history has that it had body repairs to the value of £950 only done a few days before purchase & a bumper swap a few days after my deposit was paid.Not a word was said about this.Has the Honda garage got the right to hide these details from me?I am now selling the car but obviously have to provide the service history for my p/ex which could maybe impact the sale???Would appreciate what owners thoughts are please.Thank you.- Manual
Hi Tonydee, I believe there is no Haynes manual for the CRX, however, there maybe a Clymer in the USA? other than that, I also have a PDF genuine Honda CRX workshop manual, if that's any good.- 1998 Civic Aerodeck 1800 VTI
Hi guys, newbie here, had plenty of 1999-2001 civics enjoying the windows dropping, steering column loom failing and the CV boot’s costly repairs. However, rude as you like, seeking advice on an Aerodeck that has been in the family from new. Can’t get any proper info on these so wondered if I could get a link or two from the group on their history. I know they are quite rare now and dare I ask how much they are worth? Many thanks, Paul- Headlamps
