  2. Fleecedbymysonagain joined the community
  3. Yesterday
  4. If you can neaten this up a bit, make it square then measure the thickness of the bumper plastic and get the right edge trim from the link I'll stick in, or similar. I had similar with an old beloved Volvo xc70. I used my jig saw and hacksaw and got a straight edge but it needed a bit of trim and makes a huge difference tbh. Also I'd spray all that visible silver metalwork now exposed an ugly looking in a matt finish spray paint or brush, nothing to reflect light back so nobody will even spot it and many towbars and their mounts show rust which is annoying, might be worth giving the new fittings a quick paint over. ps If you paid for that you need to have words or at the very least leave a disparaging review with a pic because that's not a professional standard of work, looks like a work in progress TBH. Good luck. https://www.amazon.co.uk/Rubber-Self-Adhesive-Protector-Material-Channel/dp/B0BK83RSZH/ref=sr_1_2_sspa?sr=8-2-spons&aref=BXCCCyRAoG&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY
  5. Hi. Civic 5 door hatchback 2015 (9th gen) 1.6 diesel manual, 66k miles. Bit of advice please. I only do the brakes on this car as the garage does the rest, spring replacement, oil changes etc servicing to keep the service history going, it's a dear game these days looking after a car. It's my wife's car so I don't drive it very often. I need to remove the mahoosive under tray to get to the underside of the engine to investigate an odd noise from the engine bay. The metal section is stuck fast, the fittings have rusted in place and it also appears to have been rivetted although they could be factory fitted, no clue. Anyhow I'm not sure it's going to go back on as many clips are damaged already or missing. Do many of you guys run without the front undertray ok? Got to be better for rust protecting too surely.. I'll also be looking at removing some of the rear under protection as is looks like it's gathering road rubbish, stones etc. I live very rural and our roads are a mess. The other issue is the windscreen spray pump, it's not working. Is it a generic one or a Honda specific part please and is it accessed through the wheel arch liner or another access point please? Thanks.
  6. Last week
  7. I would look up to see who your nearest automotive air conditioning company is. Reason being, correct diagnosis and supply of parts (which may be out of stock in most other workshops) Ebay is quite good to look up parts but old Honda parts are getting quite hard to find nowadays
  8. Hi There I need to get a replacement Air Con Unit fitted on our 2005 FR-V 2.0 Sport Petrol car. We are in South East London. Any suggestions on where might do this well for us and where to get the parts from if necessary? Thank you! Ruth
  9. Ruth joined the community
  10. Pimpampaume joined the community
  11. one of the most iconic taxi's in the world (that and the American Checker Cabs)
  12. It's generally found near the intake manifold area on the engine. - what is the issue with the PCV valve?
  13. John W joined the community
  14. I'll have a look. All the mats are dry which strange. Thanks for your response Trevor.
  15. Had to post this. One of the jobs I did was to drive a FX4 Fairway, It was GREAT !!
  16. Certainly sounds like a detent issue for sure
  17. Check out this address, it may help, Exoracing Ltd https://exoracing.co.uk › blog › how-to-install-honda-detent-springs
  18. More info required here...
  19. Crv jumping out of 2nd gear
  20. Shaun62 joined the community
  21. Earlier
  22. Neil Coumbe joined the community
  23. Paul McDowell joined the community
  24. jim maclachlan started following Trevor
  25. hi all I own honda fr-v 2008 2.2 n22a2 engine but im unable to find the pcv valve. Can anyone please spot its location ? Thanks
  26. Out of lots of bikes I have owned 3 have been Hondas and all have impressed. I drove an Accord for some years until it was written off and later I bought a Civic 1.6 SE Executive for my wife. We have owned it since 2005 and it was used by all the family when needed. Always serviced annually it has not been so thoroughly cared for recently, other than annual oil changes. I would like to think that it could continue giving service either as a restoration project or even as spares for another car. I would like it to go to an enthusiast rather than just a breaker. If no one is interested I will just put it on ebay. The body is reasonable and the engine/gearbox as sweet as ever at around 103000 miles. Underneath is a different story. Still in use with MoT to 03. 04.26 it rocks and rolls like a boat but the leather interior is as comfy as ever. Is it of interest to anyone on here?
  27. WOW! what a wonderful old Honda - cannot say I have seen one of those for at least 40+ years Hopefully someone will buy it to restore it back to its former glory
  28. not sure, sorry! but I would try to find the most reputable rebuilder rather than the cheapest as they are incredibly complex and expensive to put right afterwards. Surprised there are no exchange / rebuilt boxes out there
  29. Looking for an automatic gearbox or sumone who can repair it near glasgow
  30. Replacing the heater fan. Honda FR-V
  31. Hello, My Dad died in August 2025. He had kept an old N600 in his garage for 40 years - always planning it to be his 'next project'! It is not in good condition, but I would say it's surprisingly good for 40 years! It hasn't run since approx 1985 - so it would require a complete rebuild. I'm not hoping for much - would just like it to be of some use to someone! At the very least, is there a market for spares etc? (ps: the photo is a bit sad - I have since cleared away all of the surrounding rubbish! As you can see, the engine and chassis are still 'in one piece'!)
  32. Hi i am trying to remove the screws which holds the fan blow, first 2 screws are easy to access, however, the third screw is difficult to get to, has any replace fan blower on FRV or has any tips on how to reach the third screw? Thanks
  33. eBay link to a Smoke Generator: Smoke Generator
  34. Also, it could be leaking through the tailgate seals or even rear screen washer hose is damaged and allowing water to drip into the boot area. The ultimate way to resolve the issue is to run a Smoke Generator inside the boot area and see where it comes out from
  35. More than likely coming through from the rear light clusters - worth removing them and seeing if the gaskets have been letting water past them. If so, and before refitting it would be prudent to smear some silicone on the gaskets before refitting them
  36. Thats good to know as a recommendation for others, thanks!
