Gslater
  1. Just had a regas on the air con and discovered for following issue Air con was desperate for regas so had it done. Use to work fine last year despite not super cold due to needing the regas. however after regas it’s playing up. When sat on idle everything is engaged and the compressor is spinning but no cold air. But when you apply some revs after a while idling it’s goes super cold for a few seconds but then starts to warm back up. I have removed pollen filters which were a bit old, garage has told me pump is dead. But I’m struggling with this has the pump is spinning at idle but not cooling, and when revs are applied it wakes up and cools for a few seconds. Could anyone advise as to whether this is a simpler and cheaper issue possibly than a whole new compressor ?!
  2. Hi Trevor, only thing that happened is one day the rear window switch stopped working for a few seconds but then finally put the window up. When I got back in the car an hour later all the passenger windows never worked again. I had on that journey prior to the fault had to press the window lock a few times due to kids, which is why I think it’s that switch cause the unit is now behaving exactly as it would if the window lock was activated even though the switch has no effect anymore.
  3. Gslater joined the community
  4. Hi all, I have a 2005 1.7 FRV. A while back I had a sudden window issue, the drivers window switch works perfectly but all other windows won’t work from either the master unit or the door switches. I’m feeling the power window lock button has failed in the unit, all fuses fine, I did have to use this regularly as I had young twins playing with the windows, however I want to get the windows going again. I’m happy to fit a new unit before spending the amount I want to ask if anyone has had this issue and what the resolution was, or anyone who has the knowledge to point me right
