FBogdan
  1. I would not trust this item from Aliexpress, nor the seller. Strangely, they charge a pretty big amount for delivery services, but still they estimate around 2 months for delivery in my country. ~ 45€ delivery fees ...I would expect a faster and dedicated delivery at this rate.
  2. Just replace the CVT oil only with OEM Honda CVT-F. My Jazz is about to reach 200k km. I took it with juddering symptoms at 80k km. Judder appears usually after 3-4 years after oil change or 40-50k km range. I just change the oil and the magic happens again 🙂
  3. Multiple causes: 1. Diesel fuel pump is broken 2. The compartment where is the diesel filter has a small dent and it gets fake air intake there. 3. Possible misfire from sparkplugs Get a diagnosis, preferably with Honda HDS software.
  4. First check the fuse panel. If the corresponding fuse is OK, than you need to investigate further the wiper engine connections and the engine itself.
  5. Hi! Any API category above SJ or SL is superior and you can use API SN without fear, it is better than hanbook recommendation. Beside the OEM Honda engine oil, if you stick to 5w30 or 5w40 viscosity index, you have a lot of good oil brands at your disposal (Liqui Molly, Ravenol, Motul, Mobil1, Yacco, etc.). I know that some honda dealers are using Castrol engine oil in after warranty service, but I don't trust Castrol as in my country this is the most fake fabricated oil (I live in Roumania). As long as you keep a yearly oil change interval or max 10k km, you can use the cheapest oil which respects the handbook or is above those specs.
