norm
  1. car battery dead. Need to use key to open door, but cannot open boot to get jump leads. Any ideas on how to get into boot
  2. Hi. Thanks for that. Unfortunately I've been advised that the whole suspension arm (front) and hubs (rear) need to be replaced according to honda..
  3. Hi, I'm looking to source parts/information, so if anyone can help it would be greatly appreciated. Just had front n/s lower suspension arm replaced because the ball joint was worn...part cost me £670. I'm now needing to replace front o/s one, and the 2 rear hubs (again because ball joint worn). I've priced them all with Honda and parts are going to around £1500 plus VAT plus fitting. Does anyone know if the ball joints can be replaced on their own (without replacing hub/suspension arm), or, apart from Honda, is there anywhere else these parts might be sourced?
  4. Thanks to you both. I do like my hondas. As seems to be the case quite often on these forums, I'm looking to source parts/information, so if anyone can help it would be greatly appreciated. Just had front n/s lower suspension arm replaced because the ball joint was worn...part cost me £670. I'm now needing to replace front o/s one, and the 2 rear hubs (again because ball joint worn). I've priced them all with Honda and parts are going to around £1500 plus VAT plus fitting. Does anyone know if the ball joints can be replaced on their own (without replacing hub/suspension arm), or, apart from Honda, is there anywhere else these parts might be sourced? Thanks
  5. Hi, just joined. Have owned Honda's since 1996. Currently on 7th Honda Legend, a 2008 version. Great cars until you need parts.
