Ac.lmyx
  1. Introduction: so I have myself a Honda Concerto, and have recently upgraded all speakers. the fronts were common sense, however when it came to the rears. I realised it wasn’t as simple and there was no write up on it. Tools needed: 17mm socket & a 3/8s ratchet 8mm socket ( I used a long 8mm ) and a quarter inch Ratchet. a pozzy screwdriver. Plastic trim tool. * I will add pictures also * To start off. the speaker is underneath the plastic shelf. To remove this you will need to undo 4 pozzy head screws, this will then undo the shelf. However, You will need to fold the seat down, and using a plastic trim tool. Pop off the plastic top off the seatbelt guide. once this is done, There you will see a 17mm bolt and a 8mm nut that you need to remove to undo the seatbelt runner/guide? This will then give you access to slide the plastic shelf covering the speaker off. Once you have removed that, you can then using a screwdriver undo the 4 screws holding the old speaker in place & begin with connecting and fitting your new set in. What size speaker?: for the rear I literally just bought the Pioneer TS-R1350S. They are 13cm and are the perfect fit. And for the fronts, I reckon you could go to the next size up. funnily enough, I did not take pictures of them fully fitted. ( it started raining ) But I can add a picture of them later on, ( take it from me, don’t remove the circle speaker top😂 as they will just snap :’) ( nothing a bit of super glue won’t fix - don’t @ me haha
