CRV Pres15
  1. I have had the same issue for Months. I have done all the items you have mentioned & spent tens of hours trying to resolve it. I have even purchased a genuine OEM hatch seal & still it leaked. It turns out that when you remove the seal & expose the edge of the inner & outer panels there are Gaps between these. I have run a small bead of Seam sealer to seal these gaps around the perimeter & smoothed off with my finger. I then installed the gasket again. No leaks so far....even with thus constant rain we are having. IT is worth noting that the panels where they are joined vary in thickness around the perimeter. To make sure the seal when refitted was a snug fit it's best to compress the seal & close the gap (recess) that knocks on to the panels. This does ensure a snug fit. Hope this helps.
  2. Thanks for the reply, I did anticipate that I might need to plug in. Hopefully I can borrow one & access the menu.
  3. Hi All, New to the Forum & hoping you good people on here can solve my issue. I purchased a 2015 Crv 1.6 I dtec AWD just over 2 years ago. It hasn't covered many miles in that time so I thought it would be a good idea to give it a service. Have completed the service I then tried to access the system to update the service maintenance. I have seen a few methods of accessing the maintenance info on YouTube & the like. I've tried accessing the system by the steering wheel/ Dash dimmer light & the touch screen but unfortunately I cannot access the system by these methods. Am I missing something? Or is there a simple explanation. Any help & comments this would be appreciated.
