Hi. Does anyone know where I can get a bottom ball joint for my Honda 2.2ctdi FRV 2006? I was told by Honda that I couldn't buy just the ball joint and would have to buy the complete hub carrier for nearly £300. I ended up doing this for the drivers side (crying as I did so) but now the passenger side will soon need replacing and I am loathe to do so again. I have the old ball joint from the driver's side in my hand so I know it does separate from the hub carrier. Has anyone else had this problem and been able to overcome it? 🤞 It's not the sort of part that I want to get from a breakers because it would undoubtedly have wear issues too. Hoping someone will be able to help, Phil.
Edited by Philhappycat
  • 4 weeks later...
  • 2 months later...
  • 4 months later...
Hi. I'm new -Hello.
I've also got the same ball joint issue.
I'm also struggling to find just the ball joint. Honda sent one which was the wrong size and all the eBay ones look the same. I don't suppose you have a link or picture of the one you brought?
Thanks in advance.
