Just bought myself a 2003 CR-v with sat nav & cd system...
Usually there is an accessory position on the ignition swith, not on mine though!
One turn of the key brings all dash lights on then next turn starts car, also the radio has to be turned off manually,
ie there is no position on the ignition switch for accessories, radio, windows etc...
Is this normal?
Thanks guys
Sorted...didn't realise you had to push key in to turn to lock position.
next problem, why can I remove key when in accessory position ??
